Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
DIY: Repair seal wear grooves on drive shaft
  • DIY: Repair seal wear grooves on drive shaft
    I have a 1998 115 2+2 with 800 hours on it. This winter I replaced the water pump impeller and decided to replace the seals under the water pump housing.
    When I removed the seals I noticed that they had worn grooves in the sealing surface, which would reduce the life and effectiveness of new seals.
    By design, the sealing surface is replaceable, but it requires removal of the driveshaft, which in turn requires that the entire lower unit be disassembled.
    I did some research and decided that some Speedi Sleeves could be used to repair the shaft. Speedi Sleeves are stainless steel wear rings commonly used in industry to repair seal surfaces on shafts. They are ground to exact dimensions so that they press on to the shaft. A speedi Sleeve is only 0.003” thick, so the original seal can be used.
    The correct Speedi Sleeve part number for this application is CR 99103
    Here is a picture showing the grooves in the drive shaft. These grooves aren’t real bad, and just replacing the seals probably would have worked OK, but I wanted to try the Speedi Sleeve solution.
    I had to use 2 sleeves, as there are 2 seals that are spaced too far apart for a single sleeve. This picture shows the first sleeve pressed in place. I used a piece of PVC pipe and a rubber mallet to pound the sleeve in place.
    I have actually pressed the sleeve on “backwards”, but the radius on the wear surface of the shaft allowed me to get the sleeve started, and if I had pressed it on the other way I would not have been able to get the flange off of the sleeve.
    This picture shows the second sleeve pressed on to the shaft. Note the PVC pipe is visible on the left. You can also see that I’ve removed the flange from the 1st sleeve before pressing the 2nd sleeve on.
    And finally, here is a picture of both sleeves in place.
    I’m expecting that this repair will last for the rest of the life of the engine.
    Re: DIY: Repair seal wear grooves on drive shaft
    They work great as they are harder than the shaft was, we put them on the other way with loctite and leave the flange on it don't hurt anything.
    • #3
      I could have left the flange on the 1st one (if it was turned around the right way), but not on the 2nd, as a seal has to pass over the first sleeve and rides on the second sleeve.
      • #4
        That was an AWESOME post!!!! I think it would be a good FAQ post, because everyone will run into this problem sooner or later. The pics really make it great. I'd like to know where you ordered them or bought them. Also, do you just measure the shaft with a caliper and go get it because they have all different sizes or what?
        BRAVO,
        JBJ
        Not a certified mechanic but I have at least 2 shade trees in my yard and my wife always says I'm certifiable. So remember that when you follow my advice
        • #5
          BRAVO,
          JBJ
          Glad you liked the post. To answer your questions:
          Do a google on Speedi Sleeve and you will get a lot of hits. I found a catalog that lists all sizes available. As you suggested I measured the shaft with a pair of calipers and picked the proper sleeve from the catalog. I ordered the sleeves for this project off an internet site, but I also used Speedi Sleeves when I replaced the bearings on my trailer, and I bought those sleeves at a local NAPA.
          • #6
            Thanks for the info. mercguy. I assume you could use them on the propshaft if needed. I may try that myself on a driveshaft or two on my oldies.
            JBJ
