Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
86-88--mercury gas oil ratio mix---200hp
  • 86-88--mercury gas oil ratio mix---200hp
    ok might be asking a stupid question here --whats the gas to ratio mix ive been using 50 to 1----seems like its doing a lot of smoking.maybe to rich mixture or not enough dont really know.been using 16ounces per 6 gals.gas
    Re: 86-88--mercury gas oil ratio mix---200hp
    50:1 is correct, BP. If you don't like the smoke try going to a synthetic oil.
    sigpic
    • #3
      thanks for the info alot of help.
      • #4
        If you are using pre mix, that might help explain your tach problems on your other posts, since the oil injection system has been disconnected or removed I would only assume somebody has changed around a bunch of wires..
        • #5
          found out it has a 14 pin connector and yes it might have something to do with it.thanks----its just that premix iam sure of it when its done ---hate the one that does itself because the gear gets stripped out and theres goes an high price repair that could have been avoided---but theres pros and cons on everything.thanks
