CULODEGATO
- Sep 27, 2007
- 7
I posted on this site a couple of days ago, complaining of an engine that would stall back to idle while driving at wot. The engine would idle fine but would not accelerate at all.
After being at a dealership and having the Merc rep involved they could not figure out the problem. I picked up the boat and started checking connections and grounds while on the water. Found a sensor under the shift linkage that was corroded. I cleaned it and instantly the boat performed like new. Apparently this sensor shuts down 3 cylinders when at idle in order to make shifting the boat smooth from nuetral to forward or reverse. The boat was randomly dropping 3 cylinders while driving. Makes a return trip from 40 miles offshore a little nerve wrecking. Just thought I would pass on the info.
Anyone else had this problem?
