Hello
Does anyone knows if there is some kind of seal between the sleeve (white tube about 4 inches long /water pump kit) from the water pump to the "TUBE-WATER-LONG" (it appears to be a long cooper tube from the engine)
The reason that I ask is that if there is no seal (or some kind of o-ring) the sleeve does not fit tide on the cooper tube and pressured water can easy escape from this junction .....
Thank you and "Safe Boating always"
Roger / Miami FL.
Roger / Miami FL.
