I have a part throttle surge at 3000 to 5000 rpm The engine was rebuilt 100 hrs ago. I just rebuilt the carbs they are wh-46 just rebuilt the fuel pump replaced all lines. runs perfect at idle up to 3000 runs perfect above 5000. the fuel line is hooked directly to the engine. it has a electric fuel pump set at 5.5 psi. I have read the other threads the only thing I notice it doesn't have is a bulb. I prime it with the electric pump. the electric does run through the factory pump. I was out at the lake it started surging I turned on the electric and it did not improve. I would appreiate any help. thank You Joe
