Re: Mercury optimax 200 stalls at idle.. please help
Did you buy the boat with the motor on it, from the dealership?
Or did ya buy just the motor from the dealership?
Did they put in the water and test the problem? Or tried testing it on a hose?
Did they check all sensor readings? Is the trottle cam adjusted right?
I think your dealership is blowing ya off...........
1. Water in the fuel will set an alarm and log an fault.
2. Fuel/air readings are good (they say), did they check vacum? What was readings?
3. If it didn't beep on the smartcraft, its not going to log a fault.
I would take back and demand better answers, if you bought the boat with motor on it.
