I have a used 45 HP mercury classic fifty outboard that I picked up last month (6-21-07) and running it on the hose it started and ran great. First trip out it ran great in the no wake zone hit the gas and it ran great for 30 to 60 seconds just fine and then it started reving up and down just like going from idel to full throttle over and over.
Then I pumped the gas line bulb and it would come back to life as long as you pumped the bulb. I figured bad fuel so I removed the carbs drained all the fuel and drained one tank (the card kits needed to be ordered). With new fuel and all the water cleaned out it ran good for five trips, about 20 gallons of fuel then it started doing the same thing.
I rebuilt the carbs, new fuel lines inside the motor, new hose from tank to motor, new fitting on tank. This motor has carbs with the fuel pump attached to the carbs so fuel pumps are new.
I removed the carbs one more time to check the vacuum port one each carb and when the motor cranks over the vacuum is working you can feel the air coming in and out. I reinstalled the carbs when for a test ride and the same problem but if you pump the bulb it will run just fine.
Any help would be great.
Thanks
Zapped77
Thanks
Zapped77
