starcraft18
- Jun 28, 2007
- 12
i am working on a 1979 140 hp mercury all the wiring insulation on the motor was cracked and missing i replaced the wires 1 at a time the problem is now when i try to start it the choke doesn't work with the key in the on position
and when you push the choke button. but it does kick in when the engine while the engine is turnnng over has any one ever experienced this problem
i don't if it was working right before or not . can any one direct me to a wiring diagram or tell me which wire is the choke wire coming out of the plug
