Can this motor be timed while running? I went through the link and sync procedures but trying set the timing while cranking the engine was quite difficult( could not see the timing marks and the wife was less than cooperative cranking the motor). I started the engine and timed it while running in a barrel. While running I was able to better view the timing marks. What are the downs of this procedure? It runs and idles great. WOT will be a seperate isssue.
