I'm replacing the power trim motor/pump assembly on my 1985 Mariner 150hp V-6. I've found a used working unit and pulled mine. In order to pull the pump/motor and replace it, I know I need to remove the two bolts marked #20 in the attached diagram (I sure hope the picture came through!)...what else do I need to remove/loosen to get the motor & pump off?
Thanks in advance,
Bob
Thanks in advance,
Bob
