50 HP Mercury Control Box
sledstew
I need a control box for a 50 HP mercury, motor serial # 5864837, it currently has a quicksilver control box on it but I was wondering which other control /throttle boxes would work for this boat. Also If I take the box apart can the lever be tightened up, it wiggles out toward the seat and is really sloppy.Any help is appreciated.
Thanks
ricksrster
Re: 50 HP Mercury Control Box
Of course you can take it apart and see what ails it. Also, you can get new parts for it if anything is broken.
achris
More fish than mountain goat
Thanks
All Merc control boxes are forward and backward compatible (old ones will work with new engines, new ones will work with old engines). If you find a broken/missing part, post a photo of it and someone will (probably) give you the part number....:)
The loose handle sound like the retaining bolt is loose/missing. Take the control box off the panel and look at the back. In the centre of the box should be a bolt inside a recess. Is it there?
Chris.........
sledstew
There is no bolt on the backside of the panel, you have take the cover off and its kind of a bearcat to get it apart,.
