I have a 1998 Mercury shifter (controls a 125 hp outboard) unit that the trim/tilt switch has gone bad on. I ordered the new switch and then began trying to figure out how to get the old one out and new one in. the handle is black plastic and seems to not be able to be taken apart. I can see the wires running from the bottom of the shifter and through the hole in the console and they plug into connectors inside the console. That looks easy enough. Does anyone know how to take apart the shifter, remove the old trim/tilt switch and replace it? Does the entire shifter need to be disassembled to do this? Any help is greatly appreciated!
