charliegiggles
- Oct 19, 2006
- 50
Not sure if I should be posting this trim question here but here it goes...
I don't have the manual for this model panther trim and can't seem to find it on the internet.
I have a 79' 70HP mercury outboard which has been mounted to a panther 135 trim/tilt kit.
Considering the motor is permanantly bolted to the panther trim plate "instead of the boat itself" should the manual "tilt pin" be locked to the lower unit so that the lower unit cannot come loose of the manual tilt pin?
I'm concerned if I hit something "rock" I will do some major damage to the foot if there's no give.
Does the panther have a "shock" mecanism built into the cylinder?
Thanks.
Thanks.
