Gary Spence
- Dec 31, 2006
- 8
Constantly hae problems with mercury tank connection leaking. I don't like the design with the o ring. Would changing the quick connect to an evenrude design cause any problems?
Chris1956 said:Gary, Like JR, I converted my tank fittings to OMC fittings, which work better and are more compact. I use this combo on an old inline 6 1500, which is about as thirsty as it can get. I have not had a fuel flow issue.
Gary said:Thanks for all the feedback. My Merc is a 68 110 9.8hp. Just wasn't sure if the passage way in the connector would allow the same amount of fuel flow. I'm going to try it, same fuel hose size and male thread. Will keep my old one handy just in case. Going hunting this weekend in Arkansas. Will let you guys know how it did.
