1978 Mercury 140 HP
russk1
I removed my engine for repair and upon re-installing a hydraulic hose lines for the trim, it went in crooked and will not hold a seal. Any suggestions on how to repair it?
SpinnerBait_Nut
Re: 1978 Mercury 140 HP
Welcome to iboats Russk, let's get this to the forum for you.
Merc/Mariner Outboard forum.
Russ, If you stripped the hose threads on a T/T cylinder, you may need to get a new cylinder housing. An OB Junk yard is the best place, followed by e-BAY. Same goes for the valve body. You may be able to tap it to the next size and a reducer to match the hose.
Clams Canino
If you're real lucky you can put it back in straight with some teflon tape and it'lll hold. IF you're lucky.
Do you feel lucky? Well, do ya? :D
-W
