Re: Motor just clicks when trying to start?? HELP
with the key turned off, very carefully take a jumper cables, ground the motor to battery, connect the red jumper to battery, the touch it to the big red lead on the starter. the starter should engage. if it does then the starter is good,, could be solenoid. dirty corroded connections, bad ignition swicth, or mouse chewed wires.
