Store Links Mobile - Shop Now
See more
See less
What NGK plug is hotter, BU8H or BUHW?
  • What NGK plug is hotter, BU8H or BUHW?
    Anyone know this?
    Re: What NGK plug is hotter, BU8H or BUHW?
    Take a look here. PDF file: web page
    Rick
    "Boating is Life...All the rest is just Details"
    2007 Bentley 200 Cruise
    2007 Merc. 90 4 stroke
    • #3
      Was just looking at that..can't decipher the BUHW temp. Is it colder or warmer than the BU8H.
      • #4
        Surface gap plugs don't have a 'heat range' rating.They are at the extreme end of cold.
        Watch this space......................
        • #5
          Thanks for the info. Does anyone know why merc recommends running the coldest of the cold. The compression isn't overly high. However, I know that mercs (or at least mid 80's to early 90's Black Max V6's) run hot so maybe there's the anwser.
          • #6
            To help combat the dreaded fouled plug.The fuel ration control, quality of oil and combustion is much better on newer 2 strokes - fouling isn't so much a problem so surface gap plugs are becoming less and less important.
            • #7
              For anyone is following the post.I contacted NGK and the said the BUHW is a colder spark plug and the BU8H has an actual heat rating which is hotter.
              • #8
                NGK has a cool web site with all the info you want to know about plugs. I lost the address. I will see if I can find it and post it for you if I can. Tim
                • #9
                  www.ngksparkplugs.com
                  2005 Lund Pro Sport 1600 - Mercury 60 HP 4 Stroke
                  • #10
                    Which plugs are best..
                    • #11
                      So which is better NGK BUHW or Champion L76V plugs.
                      • #12
                        I think the BUHW NGK are the equivilent replacement for Champion L76V.
                        "Many of the greatest sailors were pukers."--Thorfinn Skullsplitter
                        • #13
                          Ok, Thanks
