Re: 1957 Mercury Mark 55
Your best bet is to try to find another lower unit on ebay. Keep in mind there are two different models involved, long shaft or short shaft (driveshaft length is different). Transom heights of 20" or about 16" respectively. Lower units from Mark 35, 35A, 55, 55A, 58, 58A will work. There was a stud size change from 3/8" to 7/16" on those lower units mid 1959. I believe you can still use the newer larger stud size with enlarging holes on your mid section but I'm not entirely sure, check with Bob Grubb of oldmercs. If you can use the larger ones it opens up lower units from 1960 merc 300, 1961 merc 350, and the 1960-61 merc 400. <br /><br />If you end up wanting to rebuild your main problem will be obtaining the special tools. The water pump cartridge remover tool is impossible to replicate and very hard to find (although there is a chance you can fix the problem without removing the cartridge & driveshaft), some of the other tools have been replicated and appear on ebay from time to time along with some original tools.
