Re: water pump 25hp mercury
I know this isnt much help (since everything has been covered), but SERIOUSLY invest the $40 into a manual, the information is invaluable
<br /><br />Even if you are mechanically inclinded, or you can do this or that, it will tell you where every nut/bolt/hold down/anything else is. <br /><br />Ive taken class after class on outboards, I am certified, work in a shop, and I still use the manuals ALOT. While you may understand the general operations, every motor is different and has certain procedures for loosening this, or taking that off. Its money well spent, especially if you plan on keeping the motor a while. <br /><br />Im not preaching, but I will do whatever it takes to help a fellow boater, even if its repeating a suggestion. <br /><br />Good luck man ! <br /><br />jeff
