Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
1979 Mercury 40HP - Ignition Switch Box, Replacing wires...
  • 1979 Mercury 40HP - Ignition Switch Box, Replacing wires...
    Hey All,My 1979 Mercury 40HP's wire's are all getting old, and starting to fall apart.I pulled off the Ignition Switch box hoping that I would be able to get to the wires inside threw the bottom, but it looks like the bottom of the Ignition Switch box is siliconed in...Is there a way to replace the wires? or would i need to replace the entire Ignition switch box?Thanks.-TheChad
    2006 Lowe Fish & Ski (FS175)
    -Mercury 115HP EFI 4-Stroke
    --Mounted 3rd Hole From The Top (Middle Hole)
    -Mercury Vengeance SS Prop (16 Pitch)
    -Lowrance LCX-26C HD
    Re: 1979 Mercury 40HP - Ignition Switch Box, Replacing wires...
    Chad it's about impossible to make a permant repair to those wires, for some reason most will not solder well and crimpons are temperarey at best
    • #3
      I was looking for a Replacement, its model 332- 4911. I found several places offering a Non-OEM replacement..Are thease reliable? Or should i stick with the OEM?Thanks-TheChad
      • #4
        If it's just the insulation that's bad you can cut off the terminal and use slide on some heat shrink tubing. You can solder on new sections but you'll need a good soldering iron, not the pencil type. I used a solder station and 750deg tip to redo mine.
        • #5
          Chad Rapair/CDI are better than original
          • #6
            Originally posted by Baitis: If it's just the insulation that's bad you can cut off the terminal and use slide on some heat shrink tubing. You can solder on new sections but you'll need a good soldering iron, not the pencil type. I used a solder station and 750deg tip to redo mine.
            That's actually a great Idea, I didn't even think about that!I have a really good Hakko Soldering station.Which is better to do, Leave the origional wire, and use heat shrink to replace the crusty insulation, or cut the wire off near where it enters the Ignition Switch Box, and solder on new wire?Thanks for the help.-TheChad
            • #7
              Originally posted by Laddies: Chad Rapair/CDI are better than original
              Are you saying repairing the wires on mine is better than replacing it with a new unit, or are you saying the Aftermarket CDI's are better than the OEM CDI's??Thanks,-TheChad
              • #8
                No replace it with CDI or Rapair products
                • #9
                  Originally posted by Laddies: No replace it with CDI or Rapair products
                  Oh, Repair CDI is a brand... Do you know their websight?The 2 Non-OEM brands I was seeing were Sierra & CDI..The CDI brand is about $125-$170 and says "Requires wire Splicing", the Sierra brand is about $150-$175 and is a "Direct Replacement" No splicing.The Sierra brand, looked like the OEM Switch box, the CDI brand looks nothing like the OEM switch box.Are the non-OEM just made better, or is there something performance wise that is better?P.S. Could the switch box be causing me not to get spark? Is there any way to test the switch box for functionality?Thanks again,-TheChad
                  • #10
                    absolutely. without it, spark does not exist
                    • #11
                      Is there a way to test the switch box to verify that it is, or is not functioning correctly?Thanks-TheChad
                      • #12
                        Chad the stator and trigger can be tested with a OHM meter but a DVA is much better, do you have either available to you--Bob
                        • #13
                          Originally posted by Laddies: Chad the stator and trigger can be tested with a OHM meter but a DVA is much better, do you have either available to you--Bob
                          I have Multi-Meter, that has an OHM Meter...What is a DVA?So how do i test the stator and trigger?(I assume testing the stator and trigger, will show if the Switch Box is bad?)Thanks,-TheChad
                          • #14
                            Chad, most people don't have a DVA (direct voltage adapter) when used with a voltmeter it reads peak voltage, so lets go with ohms first disconnect the blk/yellow wire from the box its the kill wire and test for spark no spark the kill circurt is not shortedNext ck the stator,bll/yellow to grd = 3250-3650 ohmsblk/white to grd = 200-250 ohmsNext ck the trigger,brn/yellow to brn/white = 750-1400 ohmsbrn/yellow to grd = openbrn/white to grd = openif these tests are OK then the switch box is no goodthis test is for no spark on either cyl it takes a DVA to ck spark on only one cyl---Bob
                            • #15
                              Originally posted by Laddies: Chad, most people don't have a DVA (direct voltage adapter) when used with a voltmeter it reads peak voltage, so lets go with ohms first disconnect the blk/yellow wire from the box its the kill wire and test for spark no spark the kill circurt is not shortedNext ck the stator,bll/yellow to grd = 3250-3650 ohmsblk/white to grd = 200-250 ohmsNext ck the trigger,brn/yellow to brn/white = 750-1400 ohmsbrn/yellow to grd = openbrn/white to grd = openif these tests are OK then the switch box is no goodthis test is for no spark on either cyl it takes a DVA to ck spark on only one cyl---Bob
                              Thanks for the help Laddies,I could not find those exact color wires.. I've taken a picture of the wires to show you what I am working with, Maybe that will help... Click Here For The PicturesThanks again,-TheChad
