Mercury 25 HP Timing Procedure
Status
Not open for further replies.
mcdgary
Merc 25 HP #6185448 -- Have document on timing that says: First (1)(full throttle, motor in test tank), adjust spark advance linkage to align 3 dots (on flywheel)with reference mark. Second (2) (full throttle, motor in test tank), rotate throttle cam to align cam mark with throttle roller. Then lengthen or shorten throttle linkage to align 2 dots with reference. [Comment: real scary doing this in my yard.] Question 1: Can I practice this with prop off (no load) using a flush, and how close might I come. Question 2: Won't the throttle cam and throttle linkage effect (1) at first trying to get 3 dots for spark advance? [Comment: the 3 dots are way to the left, adjustment in the spark advance linkage is as far as it can go - none left.]<br /><br />Help?
Laddies
Banned
Re: Mercury 25 HP Timing Procedure
It must be done in a test tank or on a boat tied up or less the engine will over rev. and read over a throttle cam adjustment again thats not what it says I my manuals
Shile
Well...I need to do timing on my M25xd...but how can I see 3 dots?When motor runs flywheel is also rotating..
kennyrmarshall
I have a 1990 mercury 25hp 2stroke when I got it the guy said the linkages were out of adjustment.i cant get it to start because of this.it has spark and fuel question is how do I get linkages correct
MOD EDIT: please review the forum rules - old threads and hijacking.
Status
