this is a 2 cyl 20hp 1987 Mariner, tiller handle,manual start. i replaced 1 coil because I was not getting spark on one of the cyl. I then replaced the switchbox with no luck still no spark on that cyl.The trigger and the stator would be the next on the list but via the Seloc repair manual which says if i put a Meter on the black\white wire coming out of the switchbox and the other lead on ground and turn the engine over I sould get a reading between 4-106 VDC, well I got 42VDC which means the switchbox is good and getting power.My ques. is why wouldnt I be getting spark to that one cyl. All seems good between the spark plug and the switchbox.Any help would be great,thanks,Ron
