Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Prop slipping on a '67 mercury 110, 9.8 hp
  • Prop slipping on a '67 mercury 110, 9.8 hp
    When I try to open up the throttle, the engine revs up real high and the boat slows down. I'm sure it is slipping somewhere. I first thought maybe the pin but there is none. Then took apart the gearcase thinking it might be the foreward gear, but it looked fine. I have it all back together now and would like to have some advice on what my problem might be. THANK YOU, Jon
    Re: Prop slipping on a '67 mercury 110, 9.8 hp
    jon,I think you need a new prop.Make sure you put gearoil back in the gearcase.DHP
    • #3
      I put gear oil in. What type and where can I get a prop for my engine?
      • #4
        Mercury marine or Michigan Wheel
        • #5
          What about re-hubbing the old propeller? It being loose is what would cause it to slip, right? Would it be worth it? THANK YOU, Jon
          • #6
            most prop shops won't do the smaller props because the props tend to crack but if you can find one that will do it, it would be fine
            • #7
              There is a prop for this motor on ebay right now. Item number: 4522935576. Ends Feb 2.I have also had one of these re-hubbed, no problem, $35.These are great old motors--enjoy!
              • #8
                I found a prop at a local salvage. It ran good in the barrel but am gonna take it out for a test run tomarrow. Thanks guys
                Back to Top
