Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
spark plugs for 2002 225 Optimax
  • spark plugs for 2002 225 Optimax
    What is the current correct NGK spark plug number for a 2002 225 Optimax? I hear that Merc has changed from the PZFR5F-11 to something else.Also what else works in Champion or other brands?Thanks,dougj
    Re: spark plugs for 2002 225 Optimax
    I don't know of any switches from the PZF. It is a great plug but it burns in the wallet. I have surviced many optimax'. Some people didn't like the idea of spending 16.50 a plug and tried something else my advice is don't. Those NGKs are expinsive for a reason, they have an iridium tiped electrode that doesn't wear near as fast as anything else. Since the Opti. is a dfi the spark plug is igniting a stratified fuel charge which requires a much hotter spark. The CDMs throw about 50,000 volts each time, wich will make short work of most plugs. stick with the NGKs!
    • #3
      The proper spark plug for that engine is the NGK "IZFR5G" the Mercury part number is "33-889597 001" with a srp of $15.10 Make sure to gap then at (0.031) and don't use a gapper that pushes on the center electrode.
