lmccollum4
- Aug 31, 2003
- 9
Hi, I have inherited a 90 hp Mercury, it is a 1978 model outboard that runs great. I am familar inboards, 4 cycle motors, but not outboards. The problem is my father inlaw once said you don't have to mix the oil in the gas on this motor, but if you don't put oil in the gas, where does it go? I think he implied there was a tank somewhere just for the oil and the oil mixed with the gas. After looking around on the boat, the only tank is a gas tank unless there is a tank built into the engine itself. I took the cover off the engine on one side the gas line comes in, connects to somekind of a black box and then goes up to the carbs. Also connected to the black box is a small hose that goes over to what appears to be the engine block. Any ideas or should I mix oil in the gas?
