Hello all. I have an 1985 35 hp mercury outboard with mercontrols. The control has an outside lever for the throttle/shift and an inside lever for idle/throttle control.<br />My problem is that the throttle shift lever goes well beyond the 90 degree position to get to full throttle. That is to say that it is pointing slightly downward at full throttle and not at 90 degrees. Is this ok, or is there an adjustment to made back at the motor were the cables attach to the motor?<br />Thanks in advance, Roger
