I have a low water flow problem out of the pee hole on my 1995 135hp Mariner. I changed the water pump which still looked good. Then I changed both thermostats and when I did that I flushed the lines also. I still have a low flow which feels like fairly hot water. I have ran the motor for hours like this but I feel that I might be damaging the engine. I have no temp. gage but the motor runs fine in this condition. Is this Normal. I have owend other motrs but the pee whole seems to have much more power. The moter has to run for 5 min. with the bunny ears before water flows from the pee hole<br /><br />please help me<br /><br />thank you
