Rob Koller
- Jun 10, 2004
- 1
Great forum,<br /><br />I just joined, been reading up on the Mercury 115, and I just ordered a maintenance /repair manual from iboats.com for this Mercury 115.<br /><br />I thought I would post my engine issue to see if there is some experience out there on where to begin. Have had this engine for over 25 years with minor issues, and got the engine serviced as required, seems nobody wants to service this engine anymore they all say it's too old for them...so it's time to learn myself.<br /><br />Issue: With a good battery and even when jumpered to a car battery with the car running, I get almost no cranking from the electric start (it just tugs a bit). Manual pull starting did no good as far as getting the engine going, but was easy enough to pull (nothing seized). Tried some engine start fluid ( removed spark plugs and squirted it in) and got a sputter only once. Tried and tried pull starting to no avail (would manual pull and try to get the starter to help crank with my buddy running the ignition switch full on at the same time. Jumper wires got warm , so juice was flowing. I am guessing the starter motor needs to be pulled out and checked, maybe brushes ? , maybe corrosion on wiring ? Can it be rebuilt or where can I buy a new one?<br /><br />Before I do all that, I am wondering if wire corrosion or connection issues could be the real culprit, so an easy trick for checking the starter motor directly would be a good idea. Can I run power direct to the starter for testing, with out causing damage?<br /><br />The engine was last running two seasons ago, and this issue of a poor starter cranking power was getting worse and worse before. We always thought it was because we had a bad battery in the boat. I have noticed a few topics that talk about getting all terminals and connections shiny clean, tight, and re-waterproofing...maybe I should redo the battery terminals, maybe all the wires between the battery and the engine....is this a common issue?
