I have a 1999 225 Merc Opti Max. I have lost about 2 inches of my skag and bent two blades of the SS prop. I have a bad vibration at about 1500-2000RPM but the everything is smooth as silk at 4000 RPM. Can the shaft be bent and act this way? Or can the two slightly bent prop blades cause this?<br /><br />Also , what is the procedure to remove the lower unit? Must it be removed to have the skag rewelded?<br />Can I repair the prop without heat?<br /><br />Any info will be greatly appreciated.<br /><br />Vic D<br /><br />Any
