Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Direct Voltage Adapter & other merc electrical testing equipment
  • Direct Voltage Adapter & other merc electrical testing equipment
    What does it do and why is it $65 and can I get by with something else (maybe from an electrical supply or take direct readings and convert)? Also, is there a cheaper way to test electrical components than purchasing wireing harness testers for each componenet at $30 + each - can I make my own or use a clamp-on type testor?
    Re: Direct Voltage Adapter & other merc electrical testing equipment
    The DVA meter will let you know exacty what is wrong with the ign system, Snap-on makes a variance of the device as well.TMD
    • #3
      The adapter at www.esitest is 35.00 US. Trent says you use the ac scale and convert reading by X 1.414, should get you close. You should be able to make the jumper wires. You did not say what engine, year, model , number of cylinders. To do a lot of ignition work, I would buy peak reading meter. Also seewww.stevensinstrument.com .
      Help somebody every day, if you can.
      • #4
        Thanks - that's good info.
        • #5
          http://www.sfu.ca/sonic-studio/handb...an_Square.html That's where the 1.4 comes from - not sure if this will work if your voltage wave is not a sine wave. Just if you are interested.
          Back to Top
