Re: What to lube steering bar with
I'm a mechanic in the military and us greasemonkeys use grease on everything. Battery terminals, other electrical connections, tow shackles, P.brake handles, ect. ect.<br /> Axle grease or any kind of thick petrolium will keep oxygen off of any metals once applyed. Especially whith batt terminals, it keeps the yellow nasty corrosion off. Rust as well. All corrosion and rust is is a chemical reaction with oxygen and moisture.<br /> Heres sone more advise for you to apply grease on your boat. That pully crank on the front of your boat trailer to pull the boat on from the water, apply grease all over those gears and on all those little moving parts to prevent rust.<br /> Put some inside your trailer lights all over where your bulbs connect at to prevent corrosion.<br /> Apply some inside your trailer light hookups and your truck trailer light hookups to prevent corosion.<br /> Smeer some all over your Batt terminals to prevent corrosion.<br /> Take your motor cover off and apply some on all electrical connections especially on your switch box, coils, starter, cylinoid, and anything else you can find.<br /> Apply some in any general area, any moving part, and any electrical hook up you can find.<br /> Metal+grease=love
