Re: How much to change from prop to jet drive ???
Don't know what the cost of the jet drive will be, but it will decrease your horsepower by about 25%. You will need to think about why you want to go with the jet outdrive also. You will probably not be able to carry the load your boat is capable of carrying, especially in the front, because the jet will "blow out."<br /><br />They are fun for rivers with boats with shallow drafts, but make sure you research the jet drive advantages and disadvantages closely before jumping in. If a jet suits your needs, it will be a blast!<br /><br />BTW, jet kits are easily accessable for almost any engine.
