Tom H. Smith
- Jul 26, 2003
- 7
New to board and boating. Thanks in advance. Have a 1993 25 Merc eletric start and am changing impeller. Four lower unit bolts disconnected. Where do I disconnect the gear linkage shifter in order to drop the lower unit? Is there a nut to loosen or bolt to take out or what? Should the motor be in gear or neutral while doing this? Any other tips? Thanks much.
