I have to adjust the shift linkage towards my boat 3 or 4 turns so it crunches into reverse properly as now its just making crunching sounds..<br /><br />I twirled the top cable 3 or 4 times towards the boat.. But i don't know if i have to twirl the bottom one.. The top one which i twirled moves the distributor.. The one at the bottom seems to be bolted onto the shaft and moves something inside.. If i have to twirl the bottom one a couple of times to the boat how would i remove the bottom cable so i can take it out as i seem to be having trouble.. Can someone give me the exact procedure<br /><br />Thanks again
