Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
need firing order "81 Mercury 115 inline 6
  • need firing order "81 Mercury 115 inline 6
    looking for firing order for my 81 merc inline 6
    Re: need firing order &quot;81 Mercury 115 inline 6
    if the firing order is wrong could this cause the engine to run ok at idle then bog down under loads
    • #3
      hello all in line 6's are 153624
      • #4
        Bogging under loads is most commonly a fuel starvation issue.
        • #5
          I was told the plug wires go straight across #1 to #1 cylinder and so on is this correct
          • #6
            i have the manual that a has firing orders and i dont see the any of them thats 153624 as posted before, i'm not sure what motor u have but i'll post thismerc 90-140 hp 6 cylinder with distributor-less ignition is 1-4-5-2-3-6merc 900 1150 1400 1500 and 1500xs distributor cd ignition is 1-4-5-2-3-6v6s firing order are all 1-2-3-4-5-6 in my manualgood luck
            • #7
              Thanks....think my problem has been found though fule troubles but stripped the top carb and made a world of difference
