I recently bought an old bass tracker boat with a 40 horse mercury on it. A buddy of mine said that the motor is supposed to lock down when it is put in reverse. However when I do, it doesn't lock down. Could this just be an adjustment problem on the shaft or could it be that it's not hooked up in the lower unit? I figure if it's not working the motor will come up out of the water when I try and go in reverse. Any info would be greatly appreciated.<br /> Thanks a lot.
