• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
Mercury losing power
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Mercury losing power
    I have a '93 40 HP Mercury 4 cyl. Approx 30 min. after running down the lake at full throttle the motor sounds like it loses RPMs and starts slowing down. (I am not sure about RPM Tach is acting up also) I have checked my fuel tank vents and have replaced the fuel filter. Does the same thing. While it is in this condition you can squeeze the bulb and not nothing changes. The voltmeter says that the stator is charging while I am running at full throttle. I have had several mechanics tell me that I need a new stator. Any suggestions?
    Re: Mercury losing power
    Hi, Harbo.I agree with your tech that it is probably an ignition related problem. Seems to be heat related, too. See what happens if you remove the bonnet and add some air cooling to the top end.If it works then, put it on the muffs, at idle, and apply heat from a hair dryer to various ignition components to see if you can make it misbehave with heat. You may be able to identify what part is failing. Coils and powerpaks suffer heat failure also. If no luck there, replace the stator.Good luck.
    sigpic
