• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
mercruiser 140 will not plane out
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • mercruiser 140 will not plane out
    runs good out of water 1000rpm to 5000rpm but put it in the water 2000rpms is all it will do.it opens up out of gear but in gear it's like it bogs down and won't open up and plane out.thank you for any help!!
    Re: mercruiser 140 will not plane out
    Zounds like a dead cylinder Willy. Put new factory plugs in and run around at wfo (2000 rpm) for 15-20 minutes, then stop and pull plugs look for a different one (wet,dry,black,etc.). When ya find the different one, let us know what it looked like.c/6Hooty
    • #3
      Hooty, Thank you for your reply. That does sound like a winner. When idled low it kind of vibrates.I just put new plugs, points, condenser, and carb.They had no listing for plug wires is why I didn't replace them. It is basicly a 62 Chevy2 4 cylinder motor.Any further advice?confused:
      • #4
        WetWilly,Hooty is right on. I believe you have a cylinder going dead also. A cylinder under load is harder to fire than one unloaded. I think you need new plug wires too.
        • #5
          At idle.. Remove sparkplug wires one at a time and see if the engine changes RPM. Then replace. THe one that does not change is your problem.
          • #6
            thanks for the advice going to try right now. does dead cylinder mean bad rings?
            • #7
              sorry i did not know that you had to stay on same post. hooty
              • #8
                WetWilly, See your other post.
                • #9
                  I got the boat from a friend.I traded a truck for it.I took the boat out the first time last summer.It ran awful and would not plane out. Come to find out the engine coupling had broken the studs in the crank.I replaced that. Then,it would not even crank. So I replaced carberator. It started cranking at first then stopped. So then I replaced plugs, points and condenser, took it out , thought it was fine, come to find out it still would not plane out. At first I figured out 2 cylinders were not hitting. I was afraid of alot of evasive work to the motor was to be done, come to find out the previous owners did not have the plug wires in the wrong firing order. It's OK now thanks for all the advice everyone!!!
