• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
testing stator
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • testing stator
    model # OC106680100 MercuryWhat's the best way to check the stator on my merc ? The top two cyls are'nt firing so I started with the stator and the rear starboard side of the stator is leaking what looks like dried glue out of the pick-up.
    Re: testing stator
    Can anyone at least tell me what year the motor is? Thanks
    • #3
      Re: testing stator
      I'm definitely not an expert, but am trying to troubleshoot a stator problem of my own.If you put an ohm-meter on the stator leads, you should get a resistence that you can look up in the manual to compare. If it is cooked (and it doesn't sound good to me) the resistance will probably we off the scale. You can also check for a short to ground, which is bad. But look in a manual to see the specified values.cheers,mike
      • #4
        Re: testing stator
        Its a 1989 model. Swap the coils around and see if the problem moves. If you have some firing, most likely is a powerpac problem. Look at the link for troubleshooting. Stuff comming out of the stator is not a good sign. Mercury Troubleshooting
        • #5
          Re: testing stator
          And that dried-glue goo is something else! It's impervious to everything that don't desolve the stator, dist cap and other plastics.I think it's one of those "merc part#yadayada water shield coating" or something, but it is a bear to remove.It does repell water better than anything else,as it also does everything else.I was going to mention the diostributor arangement, but I think that year doesn't have one. But it's obvious Merc used the same goo.
          "Did you hear about the guy whose whole left side was cut off? He's all
          right now."
          • #6
            Re: testing stator
            YOU SHOULD HAVE 4 WIRES OUT OF THE STATOR TO THE SWITCH BOX TWO ARE SOLID IN COLOR TWO WITH A STRIPE.GET A OHM METER @ ACROSS THE SOLID TAKE A READIND SAME ON THE STRIPE.
            • #7
              Re: testing stator
              the top two cyls do start firing once you get the rpm's up to about 4000
              • #8
                Re: testing stator
                THE STATOR PUT OUT HIGH @LOW VOLTAGE.MY FORCE 120 WOULD NOT IDLE NO MATTER WHAT I DID .ONCE I GOT INTO GEAR AT HIGH SPEED IT RAN GREAT.WHEN BACK TO IDLE SPEED IT WAS OVER.TURN OUT TO BE THE STATOR.BUT IT IS EASY TO CHECK WITH A OHM METER.IF YOU NEED A STATOR AT A GOOD PRICE CHECK OUT www.seilermarine.com
                • #9
                  Re: testing stator
                  That's what this one is doing . I kind of figured it was the stator . This all started when the fuel pump went south . Just a hole in the water.
