Re: Mercury QuickSilver 3000 Shifter troubles
I also have the same problem. Happened as I was fishing below a dam. Thank goodness for the kindness of strangers....
I have a Design II control box.
I took the control box apart using the online service manuals listed elsewhere on this site (under Adults Only). The part that the neutral button pushes in on became stuck. Basically, the shaft that the handle mounts to becomes warn by the 2 ball bearing that seat the handle in the idle position. The wearing got to the point where it pushed the inner ball bearing into the shaft that houses the neutral button. Badda-boom, the neutral button sticks.
In my research, it appears that this shaft part is no longer made (p/n 883699). Can any of the experts confirm? Is this thing worth repairing? If not, do you recommend a good swap out control box?
