Re: Mercury 8 hp jumps out of gear???
From the tiller handle there is two thottle cables to the shift linkage. There is no shift cables from the tiller handle.<br />#1 Tiller handle:<br />
http://www.dolleroffshore.com/parts_archive/MERMAR/811286/31.gif <br />#2 Throttle and shift linkage:<br />
http://www.dolleroffshore.com/parts_archive/MERMAR/811286/9.gif <br /><br />I don't think the pictures are any help. But I think your pop out of gear can be adjusted. I have the same model (1987). When I bought it and tryed it on my boat there was no real power at wot. Took a look at the linkage, took it apart and reasembled. I had power at wot, until I put it in neutral or reverse. Then the same thing again. Took it apart several times again and 30 minutes later
I found out that one joint was almost stuck. Sanded the plastic, cleaned and greased it and it works fine. Well, that is not the same problem you have. I think there is someting about the linkage. Take a good look at it.<br /><br />Good luck!
