• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
1979 40hp Mercury won't turn off
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 1979 40hp Mercury won't turn off
    1979 40hp Mercury outboard won't turn off when turning key to off position. Starts and runs fine. Replaced ignition switch (3 position switch off-on-start) and it didn't fix problem. Only way to stop motor now is to pull emergency switch cord.
    Re: 1979 40hp Mercury won't turn off
    G'Day Did you replace the ignition switch with an outboard switch or an auto switch. The outboard switch shorts the ignition system to stop the motor an auto switch will not.
    • #3
      Whaley,The replacement switch I used was the one listed in the Mercury parts manual for my boat motor (40 HP). Any other suggestions for getting the motor to stop?
      • #4
        G'Day. If the motor is switching off with the lanyard switch on the control box then the problem can only be a faulty ignition switch, or you have wired it in incorrectly
