My Outboard is not reving over 2500 RPM when in the water.<br /><br />I've replaced the following already.<br />Rebuilt Fuel Pump<br />Replaced fuel lines, primer bulb, fuel filter,<br />lower unit lube, installed fuel water seperator,<br />replaced the fuel, replaced the oil in the injector reservoir, replaced plugs.<br /><br />I haven't yet rebuilt the carbs. Should I?<br /><br />Its the same prop I've always have used and this new symptom occured this year after storage. I store the engine outside under cover and always foam the cylinders, fuel stabilizer, and leave the fuel tank full and replace plugs each year.<br /><br />This doesn't appear to be linkage related since out of th ewater it revs up fine. Its a load issue still.
