Re: mercury 115hp (water not pumping out of pee hole)
Your motor does have a water pump. If it hasn't been changed in a while it would be a good idea to replace it. No water coming out the pee hole could be no more than trash plugging it. I cleaned out one on a Merc just the other day. If you have muffs, put them on and crank the motor. Take a piece of small wire and run it in and out of the pee hole while the motors running with the muffs on it. Most of the time if it's trash blocking it, it will come out.<br /><br />Good Luck
