• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
Mercury Outboard engine problems
Page Title Module
Move Remove Collapse
This topic is closed.
Conversation Detail Module
  • Mercury Outboard engine problems
    I am new to fishing and I just encountered a problem. I have a 1978 bass boat with a 1978 Mercury 150hp V6 engine. It was running great until I ran into a sand barge. No damage done anywhere on the prop, however, when I pulled it out, the engine runs fine, but it has lost all its power and barely gets enough speed to move. Is something blocked? Please help... Mercury
    Re: Mercury Outboard engine problems
    Friend of mine had a similar problem a few years ago. He buried his lower unit in a couple feet of mud and sand and ended up sucking up some gunk into his water pump. Long story...anyway...some of the sand ended up in a couple carbs and he had to have them bored out in order to get the engine running properly again. Don't know if that is your problem but I wouldn't rule it out.
    • #3
      Awws*****t. I am assuming you didnt have a temp guage on the boat. Yep chances are you sucked enough sand into you cooling system to make one or more cylinders too hot due to constricted circulation. I know a guy that this happened to also but he sucked in some mud when he ran into a mud bank. In his case no alrms went off either but he lost the motor.Another thing that could have happened is that you hit the thing and you spun the engine main and one/more rod bearings.Two guesses. My bet is the first one. Have it flushed and looked at. I hope it isnt too late.Deerdog
      • #4
        You say engine runs fine. Will it build RPM's and just not move??? Maybe you spun the prop hub. That sometimes won't show up on the prop where you can see it. Hope that what your problem is.
        • #5
          I replied to your post under boating.Any way my bet is on the prop hub (see post)Good luck..
          • #6
            Yeah, I guess I ought to read the posts better. I saw no power and didnt see engine runs fine. I would also agree that you may have a spun or partially spun prop. Still need to make sure it is flushed out though.Deerdog
            • #7
              Hi all I just found this forum!
              I am planning on taking my Hains Sigiture out tomorrow, what I do is start up the engine so I know all will be fine tomorrow at the boat ramp, but came agross a problem with my 175 hp outboard engine won't start , It just won't kick over I have plenty of battery power!
              Would there be someone that can help me fix the problem so I can plan a day out boating tomorrow please?
              OH yer hello to all.
              • #8
                Howdy trimixdiver.
                Welcome to iboats.
                Please do not hijack old threads. Not good forum manners.
                Start another new thread and give us more info. . .model of your engine, what the actual symptoms are, etc.
                Good luck.
                sigpic
