• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
Replace Water Impeller 9.8 Merc. Please !
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Replace Water Impeller 9.8 Merc. Please !
    Just bought 9.8 Merc trolling motor water flow weak (little pisser hose) when down on low idle. Please give me instruction as to how to change it. I can do it if its not brain surgery ! The walleyes are wating !!Thanks Red !!
    Re: Replace Water Impeller 9.8 Merc. Please !
    I'll try, but you will probably need the manual for this job.I csn tell you, there is a bolt in back,one in front,and one allem bolt under the zinc. I maen,What year is she?But without the manual, that might not make much sense to you so far. The gear shaft is splined into the lower unit,and sometimes, this binds.
    "Did you hear about the guy whose whole left side was cut off? He's all
    right now."
    • #3
      Walleye Red,It's not difficult to change the impeller, but if you have never changed one before I would strongly recommend that you buy a service manual. They are not expensive and will give you the step by step instructions on that and any other maintenance you need to perform.I have a 15 hp Merc that I acquired last year and I thought the same thing about the poor water flow at idle. Changed the impeller and checked everything and it was still the same, however the motor is not overheating so I assume that's how it's supposed to be.
      • #4
        Thanks 12 & Canada but I need more Now. Just tell me I can do it! Heres my email let me Know.debraal@vbe.com Thanks Again Red !!
