• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
Merc 225 EFI Warning Horn Test
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Merc 225 EFI Warning Horn Test
    Horn no longer beeps during the test when the ignition is first turned on. Only two of the 3 warning lights work during the test. The oil light is the one that does not work. Engine runs fine. Any ideas what may be causing this other than a faulting gage? Would the bulb being out also silence the alarm.
    Re: Merc 225 EFI Warning Horn Test
    I think the sender in the tank is dirty,or rolled-over and died. To test, short the lead to engine ground. Lamp and buzzer should buzz and lamp.
    "Did you hear about the guy whose whole left side was cut off? He's all
    right now."
