• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
84 50hp. mercury with no top end . HELP!!!!
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 84 50hp. mercury with no top end . HELP!!!!
    I have a 1984 50hp. merc on a pontoon boat. The problem is I can only get about half speed under load. Have had the boat and motor since they were new . I put it in the shop twice in the last year and they cant find the problem. I have checked fuel system , carbs, compression and have spark on all four cylinders. Have been reading from this board and think it may be the high side windings on the stator. Checked impedance between red and red white and got 0 ohms ,full closed circut.Would apperciate any help.Thanks Rex P.
    Re: 84 50hp. mercury with no top end . HELP!!!!
    I had the same problem with my 50 merc,it would not reach WOT, it turned out to be the ignition box. Replaced it and it runs at 5500 rpm's Your box and or wires may be breaking down under load. Is the prop slipping?
    • #3
      Thanks for the reply Dutton , I have checked the prop. BUT I made the mistake of taking the shops word that the fuel system and carbs had been fully checked. Took the **** thing apart my self and found bottom carb was way out of adjustment and throttle linkage between the carbs was split. It is fireing on all fours now .Going to put it in the water tomarrow and see how it runs now.Thanks agian REX P.
      • #4
        Well i put the piece of junk back in the water today and it is still bogging down after about 1/3 to 1/2 throttle. Only duz this under load . Any help would be welcome Rex P.
        • #5
          pull off the top 2 plug wires to see if it is running on the bottom carb, or put some gas & oil in a squirt bottle and shoot some in the carbs to see if it picks up some rpms.if so it is the fuel sys. Pumps maybe, try squeezing the primer bulb to see if it runs more RPMs. If you pull off one plug wire and get no change you could have a bad plug or switch box, the coils usually don't go bad on these motors.
          This is free internet advice.
          Have Fun,
          corm
          • #6
            Thanks for the reply Corm. I pulled the plugs one at a time a couple of days ago and found the two for the bottom carb had no effect on the motor. Checked and found the throttle linkage between the top and bottom carb (which is plastic) was split. I replaced the broken linkage and now if any one of the four plugs is puled it effects the motor. I tried spraying fuel from a squirt bottle into each carb one at a time and neither increased the rpms. Tried pumping bulb and still no change . Running out of options. This may sound like a stupid question but are the throttle on top and bottom carbs susposed to be in alienment with each other ? Because when I replaced the linkage between the carbs I lined them up like I would on a set of carbs on a motorcycle. Any Ideas would be welcome.Thanks: Rex P.
            • #7
              Hi,You set the carb butterflys right.As for the bog problem I am at a loss.Maybe the high speed stator is bad and not producing enough power to fire the plugs.Causing it to not burn the fuel to reach top RPM.corm
              Have Fun,
              corm
              • #8
                I would rebuild the carbs, if you already haven't. I had a prob very similar to yours and it turned out that their was a gasket between the bowl, and the passage where fuel from the main jet came out. It was smashed, and old, so when it started to switch over to the main jet for power, it would bog down. As for the first 1/4 throttle, you couldn't tell anything was wrong. I would try this first, since I think the gasket kits for the carbs are something like 4 bucks a piece. Just pray stator is good, becuase it can be a job changing (getting flywheel of sometimes a real *****), and to have freshly rebuilt carbs can't hurt you cause. Good Luck, tell us how it goes.
                • #9
                  Thanks for the replies Corm and Kev_79. I will check the carb gaskets and hope its not the stator! Anybody know the numbers for the ohms test for the stator? And you check between red and red/white for high side?All and any help is very welcome! ( 1984 50 hp. 4 cyl. Mercurcy )Thanks Rex P.
