• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
lost hole shot
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • lost hole shot
    1982 merc 90 hp inline. I just recently developed a real rpm lag out of the hole I took my 21 pitch prop off(which was fine before)and replaced with my ski prop which is a 19 and usually launches the boat right out of the water.I pumped the primer ball while engine was struggling and the rpms shot right up great. Any ideas befor i start tearing into it ? remote tank,clean gas, clear line,working ventthanksdave
    Re: lost hole shot
    dave, i'd say you've got fuel delivery problems if you can get results from squezzing the bulb, check the lines for leaks,if the bulb is old get a new one,lastly your fuel pump my need a kit,,,,,,jim
    Jimbo
    93 Four-Winns 190 Horizon SS
    5.0 HO OMC
    1959 Boston-Whaler Sport 13 with-
    1983 Evinrude 60 punched-out....
    Pm me all you want.........
    • #3
      Re: lost hole shot
      Could be a fuel filter on the motor somewhere inline before or after the fuel pump, or as part of the pump itself. Also if the o-rings in the fuel connector are less than perfect it will tend to suck air through the fitting rather than draw it up from the tank.
      • #4
        Re: lost hole shot
        If your rpm lag is just out of the hole, try turning your idle air screws in about 1/4 to 1/2 a turn. If it runs fine on the top, it sounds to me like your a little lean at idle to 1500rpms. Let us know how it goes. Good Luck
        • #5
          Re: lost hole shot
          I WOULD AGREE WITH ALL.BUT CHECK YOU IDLE NOT IN BUT OUT.SET YOUR IDLE TO THE RIGHT RPMTHEN RECHECK IF IT RIGHT THEN IF NOTCHECK YOUR TIMINING ON LOW END AND HIGH END.HOSE FOR LINKS AND THAT GAS AND THE ONESIN YOUR ENGINE. P.S. PLEASE LET US KNOW WHAT WORK OUT.
          • #6
            Re: lost hole shot
            I agree with kev, I had the same prob with myMerc 1150. Opened adjust screws 1/4th turn, and that took care of the problem. Air in your fuel line can also really mess up fuel delivery. Even a fuel pump rebuild can be of help. Those old Mercs seem to be inefficient in the fuel delivery department. It can drive one a little batty.....
            • #7
              Re: lost hole shot
              thanks for the advice I'll let you knowthanks again dave
