• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
Mercury/Force
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Mercury/Force
    I heard one of the Mercury motors is desighned like the force motor. Is this motor a 130 or a 135 or am I completely wrong?
    Re: Mercury/Force
    Mercury got the Force line when the purchased Bayliner Boats. The last few years the Force motors have "By Mercury Marine" on the side below the Force Name. Mercury has dropped the Force line as of this year I believe.Mercury has a 130hp 4-stroke that is the same as the Honda 130hp 4-stroke though.Hope this helps
    • #3
      Re: Mercury/Force
      Thanks for the reply Merc140, I was told by one of the dealers I had talked with, that one of the Mercurys 2stroke was the same as a force only with a mercury name. The were suppose to have built this motor to help sell the Force after they bought them.
      • #4
        Re: Mercury/Force
        Am thinking of trying a boat with a 125 Mercury, Is this a good motor? or have they had any major problems with this motor that anyone knows of. I know the Merc has a good name just wondering about this motor, one of the used boat salesmen told me to watch out for one of the merc motors because it was basically a Force and I can't remember which motor it was.
        • #5
          Re: Mercury/Force
          was told this evening by a Merc dealer that the 125 classic is the same as the Force
          • #6
            Re: Mercury/Force
            Merc and Force motors are not the same. The 125 is the same as the Merc 115. The Force motors all used powerheads that were different from the merc's. The force powerheads were all derived from the old Chrysler motors. Some of the last Forces built used Merc legs and lower units but for the most part this stuff was Chrysler based also.The 125 is a good motor, good bang for the buck.
            • #7
              Re: Mercury/Force
              mrmerc is correct:Also, the Force line waa rated at the crankshaft for HP, while the Merc/Mariner are rated at the prop. The Merc 100, 115, and 125 are 4 cylinder motors that run on two below (I believe) 1800 RPM's and then the other two join in. The Force/Chrysler engines were (I believe) 5 cylinders. If you look at the specs on both Mercury and Force for the same HP, Example is 90 hp) the CID (Cubic Inch Displacement) is not the same. The "Sport Jet" 90 is a Force powerhead not a Mercury like it's advertised.Hope this clerifies this a little more.Craig
              • #8
                Re: Mercury/Force
                Thanks for the Replies, I have really been confused on this subject I guess !!
